Multi-point control corridor light circuit
Source: InternetPublisher:天天都吃好吃的 Keywords: 555 integrated circuit Updated: 2020/04/10
The control button switches
SB1-SB4 can be installed at different positions in the corridor. As long as
any button SB1-SB4 is pressed, the lighting EL will
light up immediately. At the same time, it will be decompressed, rectified and filtered by the transformer to supply power to
the 555 integrated circuit .
The initial voltage on the 220yF capacitor connected to pins ② and ⑥ of the 555 integrated circuit is zero,
so the pin ③ of the 555 integrated circuit outputs a high level, and the relay
K actuates, causing the normally open contact K to close, and the entire circuit enters
a timed self-locking state. state. After that, the power supply charges the capacitors on the ② and ⑥ pins of the 555 integrated circuit
, and the voltage rises. When the
capacitor charges about 2/3 of the DC power supply voltage
, it takes about 3 minutes. At this time, the output of pin ③ of the 555 integrated circuit
flips to low level, so K is released, the contact switch K is automatically disconnected, and the light
EL goes out. Just press any button among SB1-SB4 again, and the fork will re- time and turn on the light.
- Audio level LED and digital dual display circuit
- Working Principle of CCFL and Analysis of Electronic Driving Circuit
- Transistor storage time test circuit
- Corridor automatic light-off device
- One of the bead-type emergency light circuits
- Large light emitting diode display circuit
- Three-way music lantern circuit
- Electronic rapid starter for fluorescent lamps
- Bedside lamp controller circuit
- Small current anti-theft alarm circuit
- Multi-point control corridor light circuit
- Control circuit using NE555 integrated circuit_2
- Control circuit using NE555 integrated circuit_1
- Long delay circuit composed of 555 integrated circuit
- 555 timer disconnection photoelectric isolation safety protection circuit
- Breathing light circuit diagram designed by NE555
- Micromotor pedal speed regulator circuit and improvement
- The battery fast charging circuit is composed of BQ2002 battery fast charging control integrated circuit
- Use 555 to make DC-DC boost circuit
