Household light-controlled desk lamp circuit
Source: InternetPublisher:念慈菴 Keywords: Light control BSP Updated: 2021/08/14
The working principle circuit is as shown. The 220V AC voltage is stepped down by the capacitor cl, fully rectified by the rectifier bridge stack U],
filtered by the capacitor Cz, and stabilized by the voltage stabilizing plate tube, and then becomes a DC voltage. :
The resistance of the photoresistor RG is very small during the day, and the pulse signal charging to the electric charger G is very small, which cannot trigger the thyristor to conduct. The circuit of the light bulb EL
is blocked and the light bulb EL does not light up. When night falls, the dark resistance of the photoresistor is very large, causing the thyristor to turn on. The charging pulse signal of the capacitor C is very large, which can trigger
the gate of the thyristor, causing the thyristor a to conduct. At this time, the relay coil is energized. The normally open contact of the relay in the EL circuit of the light bulb is connected, and the light bulb EL lights up.
Adjusting the resistor RP can adjust the trigger signal to the door panel to be too small, thereby adjusting the conduction angle of the maximum tube, thereby controlling the brightness of the bulb
- Example of LED AC drive circuit
- Digital level display (CD40147, CD4511)
- Blinking LED circuit diagram based on LDR and resistor
- Design and production of rain control and light control timing controller based on P87LPC764
- One of the bead-type emergency light circuits
- Motor speed photoelectric control circuit
- Desk lamp dimming soft switch circuit
- Small current anti-theft alarm circuit
- 6-digit cathode fluorescent triode display circuit
- Touch lighting switch circuit three
- Voice controlled flash LED light circuit diagram
- Homemade disinfectant circuit
- Rural vegetable greenhouse lighting circuit
- Poultry warming temperature control circuit
- DC ammeter
- Junction field effect transistor mixer circuit
- Wien bridge oscillator circuit
- Inductive feedback oscillator circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Guest arrival signal recognition circuit
