Energy saving lamp circuit
Source: InternetPublisher:念慈菴 Keywords: BSP incandescent lamp Updated: 2020/06/20
Energy-saving lamps are divided into compact self-ballasted type and single-ended type in terms of structure; they are divided into double-tube type, four-tube type, six-tube type and circular tube type in terms of appearance
. The lifespan of energy-saving lamps is 10 times that of ordinary incandescent lamps , and the power is 5-8 times that of ordinary light bulbs (
the brightness is equivalent to that of a 100W incandescent lamp). Energy-saving lamps save 80% of electricity than ordinary incandescent lamps. %, and the heat generation is only 1/5 of that of ordinary light bulbs . Energy-saving lamps can
replace incandescent lamps . Save energy and benefit environmental protection. The physical appearance of the energy-saving lamp is as
shown in the figure.
The ceiling light illuminates the entire space, eliminating dark areas, and has high illumination uniformity, giving people a good psychological effect and is not affected by space and other objects.
It is suitable for bedrooms, corridors, foyers and other places.
The installation method of energy-saving lamps is the same as that of ceiling combination lanterns.
- Making a photometer with light measuring function
- Experiment on realizing photoelectric alarm using photosensitive devices
- Delayed gradual lighting with protection function
- LED Signage with RS232 Port Operation Guide
- Design and production of a practical electronic counting device
- Use NE555 to make a lighting and sound changing circuit
- SC3071 touch step dimming light circuit
- Colorimeter circuit
- Motor speed photoelectric control circuit
- Fluorescent lamp dimming circuit composed of thyristors
- stuttering correction circuit
- Pulse therapy circuit
- Homemade disinfectant circuit
- AC voltmeter
- Simple AGC circuit in transistor radio
- Crabo oscillator circuit
- Broadband high frequency power amplifier circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- common emitter amplifier circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
