PLC chain alarm control circuit used in production process
Source: InternetPublisher:jikai233 Keywords: PLC control circuit BSP Updated: 2021/09/12
According to the above requirements, the control relationship structure can be drawn
The symbols a, b and i-io in the figure are input signals, and their meanings are as follows: a: Reset button of PV-102; b: Reset
button ; 1 : Air compressor stops; 2: Central control room emergency stop; 3: Ammonia superheater outlet gas ammonia temperature is extremely low l 4; Oxidation furnace platinum mesh 1 temperature
is extremely low; 5: Oxidation furnace platinum mesh 1 temperature is extremely high; 6: The hydrogen temperature at the outlet of the ammonia superheater is extremely low; 7: The ammonia/air ratio is extremely high; 8: The ammonia/air ratio is extremely low;
9: The temperature of the platinum mesh 2 of the oxidation furnace is extremely high; 10: The temperature of the platinum mesh 2 of the oxidation furnace is extremely low. PV-102 is the ammonia gas valve at the outlet of the ammonia superheater, xV-lol is the interlocking
quick-closing valve
in front of the ammonia filter , and XV-102 is the remote control vent valve before the ammonia filter.
(2) PLC selection In order to realize the interlock alarm control function of the atmospheric pressure nitric acid plant during the production process
, taking into account the system requirements, Siemens S7-200 series PLC is used
as the controller. It has the advantages of compact structure, small size, light weight and strong functions
. The input power of the PLC is provided by external 24V DC, and the outputs are all relay
type. Taking into account the input and output of other signals and future expansion applications, a total
of 30 input nodes and 26 output points are designed (including 14 input points and
10 output points on the CPU module).
- Model rocket launch controller circuit
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- How to make a wheeled self-balancing robot using ultrasonic sensors
- Introduction to the internal structure of the Delta winding motor
- How to set up a cheap beam break sensor control distance scene using a reflector
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Motor control circuit for starting and running without phase loss
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- An experimental model of an infrared radio alarm
- Inpatient pager circuit
- soil content measurement circuit
- Poultry warming temperature control circuit
- Amplitude modulation circuit composed of MC1496
- Crabo oscillator circuit
- Broadband high frequency power amplifier circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Second-order active band-stop filter circuit
- Small current generator circuit
- Sawtooth wave generator circuit (1)
