Low voltage blocking overcurrent protection circuit
Source: InternetPublisher:小胖友 Keywords: Low voltage protection circuit overcurrent protection BSP Updated: 2021/10/12
In the protection circuit shown in the figure , in the normally open contact circuit of the overcurrent relay KA for line overcurrent protection , the normally closed contact of the low voltage relay KV is connected in series , and KV is connected to
the protected line
through the voltage transformer TV.
On the bus, '
Working principle: When the power supply system is operating normally, the bus voltage is
close to the rated voltage, so the normally closed contact of the voltage relay KV is
open. At this time, even if the current relay KA malfunctions due to line overload
(that is, the KA contact is closed), it will not cause the circuit breaker QF
to trip accidentally. Because of this, the operating current k of the overcurrent protection device equipped with low-voltage blocking
does not need to be set according to the maximum load current
IIAVI of the bypass line, but only needs to be set according to the calculated current I30 of the bypass line
. Of course, the return current k of the protection device should also avoid I30.
- Tutorial for building a remote-controlled Arduino Air-Boat
- How can we make the robot move precisely on a predefined path?
- A small improvement to the temperature and water level indicator alarm
- Light-controlled circuit design and analysis
- Design and production of no-load automatic power-off device for household power supply
- Guanghua brand anti-theft doorbell electronic lock circuit
- Homemade short circuit alarm device
- Precious home appliance anti-theft alarm
- Car audio system anti-theft circuit
- Vibration anti-theft alarm circuit
- Self-defense anti-riot circuit
- Inpatient pager circuit
- Homemade disinfectant circuit
- Peanut and melon seeds roasting machine circuit
- base amplitude modulation circuit
- Broadband high frequency power amplifier circuit
- Differential Amplifier Circuit
- common emitter amplifier circuit
- Small current generator circuit
- Home appliance repair signal generator circuit
