Light-controlled circuit design and analysis
Source: InternetPublisher:红水杯 Keywords: Light control circuit Updated: 2024/11/08
The working principle of the device application circuit is shown in Figure 5. During the day, due to the strong light, the internal resistance of the photoresistor RG is very small. At this time, a large current passes through RG, which makes the transistor VT saturated and turned on. After VT is saturated, the voltage at the ④ end of the controller DM is much lower than 1.6V, so DM is cut off internally and the lighting lamp H cannot be lit.
When night falls, the light becomes dim, the luminous flux shining on RG weakens, the internal resistance of RG becomes larger and larger, and the internal circuit of the controller DM is gradually turned on, so that current flows through the lighting lamp H to make it glow. This circuit is a soft start mode, that is, the filament of the lighting lamp H gradually transitions from red to incandescent state, and it is not easy to flicker when the filament is red.
- The meaning and importance of circuit protection, common types of circuit protection
- Build a Smart Garage Door Opener Using a Raspberry Pi
- How can we make the robot move precisely on a predefined path?
- Introduction to the internal structure of the Delta winding motor
- How to set up a cheap beam break sensor control distance scene using a reflector
- Perform surgery on the speaker protection circuit
- One-way rotation circuit of motor controlled by contactor
- Light-controlled circuit design and analysis
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- Motorcycle anti-theft device circuit design
- Light control circuit diagram using 555 time base circuit
- Chicken farm photoelectric control circuit
- Mobile phone camera flash control circuit
- Water dispenser double sheet control circuit
- Paper tension control circuit
- Infrared voice control circuit
- Chandelier control circuit
- PLC transmission line automatic reclosing control circuit
- Multi-pole leakage protector circuit b
- Haier KFR-25GW air conditioner control circuit schematic diagram
