High voltage automatic protection circuit
Source: InternetPublisher:张小哥 Keywords: Protection circuit high voltage automatic protection high voltage power grid Updated: 2020/12/14
The indicator is a high-voltage power grid automatic control protection circuit . In the circuit, VT1 forms an oscillator; VT2 forms a frequency-selective high-amp circuit;
VT3 and VT4 form a switching circuit; c9 is the protection capacitor of VT4. When no one approaches the protection circle, the switching circuit is turned on, and the relay
KA operates, and its normally open contact Point KA is connected, and the power supply of the high-voltage grid is connected to the high-voltage line. When people and animals approach the protective circle, the distributed capacitance Ci value changes, the oscillation frequency also changes, the frequency-selected high-amplification output is very small, the switching tubes VT3 and VT4 are cut off, the relay KA is released, and
the high-voltage power supply is cut off
through the contact KA.
This protects humans and animals from the risk of electric shock caused by high voltage. The installation of high-voltage power grids is mainly used to eliminate
pests in rural areas. When using high-voltage power grids to eliminate pests in rural areas, firstly, a protective area must be set up to prohibit the entry of people and livestock, and secondly,
protective measures must be taken. Ensure safety: When installing automatic control protection devices for high-voltage power grids , security circles should be erected outside the high-voltage power grid to protect people
and livestock from entering dangerous areas.
- Tutorial on making your own remote-controlled robotic arm
- Peripheral circuit of automotive motor controller power supply chip
- A simple door handle touch alarm circuit
- Introduction to the internal structure of the Delta winding motor
- Temperature control circuit design and analysis
- An experimental model of an infrared radio alarm
- Infrared blocking alarm device
- Ultra-short wave item left behind reminder alarm
- Password type motorcycle anti-theft device
- "Watchdog" anti-theft alarm circuit
- Protection circuit using uPC1237 chip
- Relay fixed time overcurrent protection circuit a
- Low voltage circuit breaker protection circuit b
- Structure and working principle diagram of various protection circuitsg
- Switching regulated power supply circuit
- One of the series-type regulated power supply circuit protection circuits
- Thyristor overcurrent protection circuit 2
- Mains undervoltage and overvoltage protection circuit 5
- Mains undervoltage and overvoltage protection circuit 4
- Small hydropower station motor speed regulation and overrun protection circuit
