Small hydropower station motor speed regulation and overrun protection circuit
Source: InternetPublisher:toothache Keywords: Protection circuit power station motor speed regulation BSP Updated: 2021/08/08
In the figure, M is a speed-regulating motor, which controls the opening, closing and opening of the water guide vane.
①Electric speed regulation. Before connecting to the grid, turn the transfer switch SA to the generator side and open the toggle switch S; after connecting to the grid, turn SA
to the generator side to be paralleled and close S to achieve the purpose of tripping self-protection. When the generator is connected to the grid and the load is sufficient, the limit switch
SQi is opened and the motor stops running; when shut down, when the turbine guide vane opening is zero, the limit switch SQi is opened
and the motor stops running. .
② Speed protection. When the generator fails, the circuit breaker QF trips, its auxiliary contact closes, the contactor KMz
is electrically closed, and the motor reverses until the limit switch sQz is opened and the shutdown is completed.
- Tutorial on making your own remote-controlled robotic arm
- How to make a wheeled self-balancing robot using ultrasonic sensors
- How to set up a cheap beam break sensor control distance scene using a reflector
- Motor automatic cycle control circuit
- Methods for Eliminating Noise of Brushed DC Motors
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Electric vehicle battery charging protection circuit
- PIC microcontroller controlled remote anti-theft alarm circuit
- A novel and practical power line anti-theft and cutting alarm circuit
- "Watchdog" anti-theft alarm circuit
- electromagnetic field sensor
- Electronic thermometer circuit
- Ultrasonic blind pathfinder circuit
- soil content measurement circuit
- Biogas concentration detection line
- Farmland irrigation automatic control circuit b
- DC ammeter
- Junction field effect transistor mixer circuit
- Parallel crystal oscillator
- High and low frequency signal generator circuit
