Star connection motor phase failure protection circuit
Source: InternetPublisher:拿铁三分糖 Keywords: Protection circuit motor phase failure protection BSP Updated: 2020/01/21
It is a Y-shaped connection motor phase failure tripping device. This circuit is suitable for motors below 7.5kW.
Working principle: Press the start button SB2, the contactor KM is energized and self-locking, and the motor starts and runs normally. When
one phase of the three-phase alternating current is disconnected, a potential difference occurs at the neutral point of the motor. This voltage is rectified and stabilized, causing the relay KA to be energized and closed, and its normally closed contact
to be disconnected, causing the contactor to be de-energized and released, the main contact to be disconnected, and the motor M to be de-energized and stop.
- Design and selection of electric control valve system drive
- Tutorial for building a remote-controlled Arduino Air-Boat
- How to set up a cheap beam break sensor control distance scene using a reflector
- Motor self-starting circuit
- Design and production of radio remote control fan stepless speed regulator
- IGBT modules block overcurrent by controlling the gate
- Design and analysis of a four-bit remote control component capable of remote reset
- Motorcycle anti-theft device circuit design
- Ultra-short wave item left behind reminder alarm
- Bicycle anti-theft alarm
- High-efficiency speaker circuit for rural stage
- Biogas concentration detection line
- Domestic KD8041 integrated phase locked loop
- Diode square rate detection circuit
- base amplitude modulation circuit
- Diode balanced amplitude modulation circuit
- Crabo oscillator circuit
- Voltage series negative feedback amplifier circuit
- Home appliance repair signal generator circuit
- Sawtooth wave generator circuit (2)
