Protect zero circuit
Source: InternetPublisher:张三叔 Keywords: Power supply system protection device household appliances Updated: 2021/09/16
The protective zero connection is
a technical measure to connect the metal casing of electrical equipment such as motors and household appliances to the neutral line of the 380V three-phase four-wire power supply system
through wires. Its function is to prevent electrical leakage once the insulation of electrical equipment is damaged. Leakage current can cause the protection device to operate or the melt to fuse,
thereby automatically cutting off the power supply, as shown in Figure 14-2. It is worth noting that in the same power grid, the same protection method should be used, and some
electrical to be connected. zero, while other electrical equipment is grounded.
- How to choose the right level of integration to meet motor design requirements?
- Tutorial on making your own remote-controlled robotic arm
- How can we make the robot move precisely on a predefined path?
- An automated model railroad layout project using a microcontroller
- Manual automatic air compressor control circuit
- Design and principle analysis of practical electric curtain remote control device
- Electric vehicle battery charging protection circuit
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- Design and production of no-load automatic power-off device for household power supply
- Password type motorcycle anti-theft device
- 13 examples of electric drag control circuit diagram
- Chicken farm photoelectric control circuit
- PLC chain alarm control circuit used in production process
- PLC transmission line automatic reclosing control circuit
- PLC light source robot hand bubble control circuit
- Harmonic current phase failure protection circuit 2a
- Forward and reverse operation energy consumption braking circuit 2
- Use fluorescent lamp starter to make household appliance indicator light
- Use light-emitting diodes to make household appliance indicator lights
- Household appliance child lock switch
