Detection parts and data of reset circuit
Source: InternetPublisher:狂妄火龙果 Keywords: Reset circuit microprocessor power supply Updated: 2021/02/23
(a) shows the structure of the microprocessor reset circuit. The power supply terminal of the microprocessor will have a process of rising from 0
to 5v when it is turned on. If it is started during this process, program confusion may occur. For this reason, microprocessors are equipped with a reset circuit
that
resets the terminal at the moment of turning on the computer. Keep ov, low level . When the power supply is close to 5v (greater than 4.6 V). The voltage at the reset pin becomes high (nearly
5 V). Only then does the microprocessor start working. During shutdown, when the voltage value drops to less than 4.6 V, the reset voltage drops to zero and the microprocessor
program is reset to ensure the normal operation of the microprocessor . Figure 25-22 (b) shows the time relationship between the power supply voltage and the reset voltage.
- Change the Zhongjiu receiver to 12V power supply
- LED digital clock language time reporting circuit
- Double tuned amplifiera
- Zhongyi brand BCD-215 refrigerator circuit
- The structure of Hisense KFR-25GW-06BP inverter air conditioner outdoor unit microprocessor control circuit
- Range hood automatic control circuit
- Minsk brand MNHCK-22 refrigerator circuit
- General frequency converter display-keyboard
- Electronic disinfection cabinet circuit
- Dole brand BD-360A, BD-220A, BD-145A, B type refrigerator circuit
- External memory circuit of Hisense KFR-25GW-06BP inverter air conditioner indoor unit microprocessor
- Detection parts and data of reset circuit
- Microprocessor reset circuit b
- High output voltage amplifier circuit
- Compaq computer switching power supply circuit
- Computer motherboard microprocessor power supply circuit block diagram
- M50462AP (TV) infrared remote control transmitter microprocessor - test circuit
- A co-located stereo amplifier circuit powered by positive and negative symmetrical power supplies
- There is only one secondary group to form a dual DC power supply circuit
- Voltage monitoring and reset circuit diagram
