Compaq computer switching power supply circuit
Source: InternetPublisher:MartinFowler Keywords: switching power supply computer power supply circuit power supply Updated: 2020/10/15
Shown is the switching power supply circuit of Compaq computer , which uses a 11A94 switching oscillation control integrated circuit and
an LM339 operational amplifier integrated circuit as a voltage comparator.
The basic working principle of this circuit is similar to the aforementioned circuit. During normal operation, TL494⑧ and @ pins should output pulse signals, VT1 and
VI2 work in the switching state, and each winding of transformer T2, 13, and T4 should have pulse signals. If a certain DC voltage is abnormal, the rectifier and filter components should be
checked along the signal flow to diagnose the fault.
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- Schematic diagram of car cigarette lighter to USB power port
- Basic circuit description of adjustable voltage regulator LM317
- Basic connection circuit of signal and power supply composed of ISOll3
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Visible laser digital control modulation driver
- Boost drive circuit composed of RT8450
- Integrated regulated power supply with continuously adjustable output voltage
- USB power socket using the car battery
- Homemade home inverter circuit diagram
- Which one is more suitable: linear power supply, thyristor power supply or switching power supply?
- What is the difference between linear and switching power supplies?
- What types of output overvoltage protection circuits are there for switching power supplies?
- What is a freewheeling diode?
- Some technologies for miniaturization of switching power supply
- Inspection methods for various components in power supplies
- Wand massager motor drive circuit
- CPU power supply circuit using RT9245 chip
- Add power supply circuit for automatic start button
- Quartz wall clock AC power supply circuit
