Reference voltage divider circuit in AD converter
Source: InternetPublisher:qoistoochee128 Keywords: Reference voltage voltage divider circuit D converter comparator Updated: 2020/02/24
Shown is the structural principle of the reference voltage dividing circuit in the A/ D converter . 256 series voltage dividing resistors are set between the positive and negative reference voltages
. Their resistance values are distributed in a trapezoidal manner. After the three-button switching control, the output is sent to the comparison input terminal of the device .
- Analysis of the flow direction of transistor current
- Which one is better, NPN or PNP transistor?
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- In-depth analysis of energy losses in oscillation frequencies
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- Types and structures/characteristics/functions/implementations of smart sensors
- Make a flameless electronic candle using simple electronics and LEDs
- What is the difference between high-side and low-side resistive current sensing
- Digital number selection machine
- Circuit structure of audio AD converter
- Using ground-based AD conversion circuit
- TDA7272 principle block diagram and typical application circuit
- Fan simulated natural wind control circuit
- Overload indicator circuit diagram
- One-half voltage divider circuit diagram
- Window comparator circuit with only one reference source
- Comparator that detects supply overvoltage and captures spikes
- Window comparator circuit diagram using RX5VT
- 10V reference voltage circuit with extremely low temperature coefficient
