Flashing light making circuit diagram
Source: InternetPublisher:super_star Keywords: lamp circuit diagram contacts relay Updated: 2020/09/05
The circuit working principle of the device is shown in the figure. Plug in the power plug CT. Since the normally closed contact j1 of the relay J is closed, the lamp H lights up. And since the normally open contact j2 is open, the ④ pin of LSE outputs a low level. At this time, the transistor VT conducts Pass. After VT is turned on, relay J is excited and closed, contact j1 is opened, H goes out, and contact j2 is closed at the same time, so the output of LSE pin 4 is high level at this time, transistor VT is cut off, relay J is released, and contact j1 It closes again, H lights up, and contact j2 opens again... This cycle works over and over again, causing the light H to flash.
![Flashing light making circuit diagram](http://www.eeworld.com.cn/circuit/upload/55ec11a60ce9426a1b221197d6b93c3a/df7f1dd2a464962261333410c48ab4a3.jpg)
- How to Make a Soft Latch Circuit
- Basic connection circuit of signal and power supply composed of ISOll3
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Visible laser digital control modulation driver
- Use pulse width modulation to get a precise output voltage
- LED rechargeable flashlight circuit diagram
- Car Audio Power Supply
- The production of adjustable voltage-stabilized power supply composed of LM317
- Circuit diagram explanation: simple switching power supply circuit diagram
- Detailed explanation of mobile phone charger circuit diagram
- Power circuit b composed of intelligent thyristor modules
- Industrial product promotion and shopping guide DC power supply circuit
- Power supply circuit with multiple outputs (MAX1902)
- 2-phase CPU power circuit using HIP6301 and HIP6601 chips
- Warm current power supply circuit b
- One of the transistor stabilized current power supply circuits
- Karaoke light controller circuit (1)
- ±15V active servo power circuit
- Common power circuits and applications 08
- Inverter power circuit made with BJ50A
