Current-voltage conversion circuit in input circuit
Source: InternetPublisher:难得正经 Keywords: conversion circuit input circuit voltage conversion Updated: 2020/09/15
Shown is the current-to-voltage conversion circuit in the input circuit
. In the input signal selection circuit,
a high-precision standard resistor (wirewound resistor or metal film
resistor from 0.1 to 900n and measured by two switches. For range selection, the current is input from the input end. After selecting the corresponding resistor through the selection circuit, it
is input into the LtA741A through the range selection switch. After the frequency conversion processing of the yA741A, a voltage value proportional to the input current is output.
- Analysis of the working principle of car garage door lights
- The meaning and importance of circuit protection, common types of circuit protection
- Car ice warning circuit sharing
- Use your smartphone to turn on/off the power in your home
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Motor self-starting circuit
- Do-it-yourself trial production of phase failure protection device
- Design and production of no-load automatic power-off device for household power supply
- Magnetic door and window anti-theft alarm
- Simple timing control circuit
- Photoelectric tracking control circuit
- DC voltage stabilizing circuit and zero-crossing detection circuit in the indoor unit control circuit of Hisense KFR-25GW-06BP inverter air conditioner
- High-rise residential walkway lighting control circuit
- 24h automatic switching capacitor control circuit
- CPU input and output and memory control circuit
- The structure of Hisense KFR-25GW-06BP inverter air conditioner outdoor unit microprocessor control circuit
- Relay control circuitb
- Intelligent iron control circuit
- Temperature detection control circuit of electric hot water bottle
