24-bit, 250kSPS single power supply data acquisition system
Source: InternetPublisher:smallembedded Keywords: Single power supply data acquisition system BSP Updated: 2021/08/23
![24-bit, 250kSPS single power supply data acquisition system](http://www.eeworld.com.cn/circuit/upload/42443c48c9470e703812cca15639d5af/f07f2d5cdfcd4a919d1c2163614173f2.gif)
Advantages and features:
*24-bit 250kS PS ADC system
*Industrial signal level
* Single power supply
application:
*Instrumentation
*Programmable logic control and distributed control system
*Electronic Test and Measurement
*Circuit functions and advantages
When sampling industrial-level signals, fast, high-resolution conversion information is necessary. Typically, when the sampling rate reaches 500kSPS, the resolution of the analog-to-digital converter (ADC) can be 14-bit to 18-bit. The circuit shown in Figure 1 is a single-supply system optimized for industrial-level signal sampling , using a 24-bit, 250 kSPS Σ-Δ ADC. Each of the two differential channels or four pseudo-differential channels can Provides 17.2 bits of noise-free code resolution at a sampling rate of 50kS PS .
This circuit uses an innovative differential amplifier with built-in laser trimmed resistors to achieve attenuation and level conversion. It uses a precision ADC with low power supply voltage to solve the problem of acquiring and digitally processing standard industrial level signals of ±5V, ±10V and 0V to 10V. . This circuit can be used in process control (PLC/DCS modules), medical and scientific multi-channel instruments and chromatographs.
- Schematic diagram of car cigarette lighter to USB power port
- Benefits of Wide Bandgap Technology for Power Converters
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- LED Driver ZD1680
- LNK304 non-isolated LED light string driver circuit
- Current/voltage conversion circuit using current converter
- LM317 regulated power supply
- Mc34063 MP3 Switching Charger
- Production of backup power supply for cordless phone
- Circuit diagram explanation: simple switching power supply circuit diagram
- Inpatient pager circuit
- Peanut and melon seeds roasting machine circuit
- DC ammeter
- base amplitude modulation circuit
- collector amplitude modulation circuit
- Diode balanced amplitude modulation circuit
- Voltage controlled power supply second-order high-pass filter circuit
- color discrimination circuit
- Power phase sequence display circuit
- Various signal generator circuits
