The process and phase relationship of the driving signal from t2 to t3 (240° to 360°)
Source: InternetPublisher:吃掉星星 Keywords: transistor coil Updated: 2021/03/14
At time t2~t3 (240.-3600): As shown in the figure, when the transistors w+ and U- are turned on, other transistors are turned off. The signal flow
is that the power supply current passes through the positive terminal - w+ transistor - W coil -_U coil - U- transistor - R806 - negative terminal or to ground.
- A simple door handle touch alarm circuit
- How to set up a cheap beam break sensor control distance scene using a reflector
- Manual automatic air compressor control circuit
- Hydraulic control circuit design and analysis
- Design and production of wireless multi-location control switch circuit
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- PIC microcontroller controlled remote anti-theft alarm circuit
- Infrared blocking alarm device
- Infrared detection alarm
- Water supply reminder after water outage
- Multi-channel patrol detection control circuit c
- Mobile phone camera flash control circuit
- Table printing machine control circuit
- High-rise residential walkway lighting control circuit
- Chandelier control circuit
- PLC transmission line automatic reclosing control circuit
- Automatic door detection control circuit
- Galanz rice cooker control circuit
- Control circuit of Gao Shida 25860T microwave oven turntable assembly
- Power supply circuit with multiple outputs (MAX1902)
