Galanz rice cooker control circuit
Source: InternetPublisher:偷熊计划 Keywords: control circuit Galanz rice cooker switch Updated: 2021/07/02
Shown is the mechanical control circuit of Galanz rice cooker . This circuit is controlled by a mechanical control component to heat it. Under normal circumstances,
after the rice cooker is powered on and the rice cooking switch is pressed , the heating indicator light will light up at the same time. After the rice cooker pressed the cooking switch , the rice cooker did not respond and the indicator light
did not light up, indicating that the mechanical control component of the rice cooker was faulty.
- What is the function of a voltage regulator in a circuit? How to connect a voltage regulator?
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- What does a rectifier do? What is the process of rectification?
- Simple Wired Spy Bug Circuit Built Based on IC741
- DIY a decorative lamp
- How to Build a Simple Temperature Indicator Circuit Using NTC and PTC Thermistors
- How to build a triangle wave generator using an op amp and discrete components
- Touch circuit design and analysis
- Star finder battery indicator circuit
- Circuit diagram of a differential amplifier circuit
- Furnace door interlock switch control circuit
- Low power timer circuit
- Driver drowsiness alarm circuit
- Improve lighting power factor circuit
- Using 74LS244 to expand 24-channel input interface circuit
- Switching interface circuit in timing query mode
- 1-O connection diagram of PLC
- 4W/5V switching voltage regulator circuit diagram
- Temperature detection control circuit of electric kettle
- Internal functional block diagram of MAX8775
