Hall element and motor starting principle b
Source: InternetPublisher:他们逼我做卧底 Keywords: Motor Hall element coil Updated: 2021/09/28
The driving principle of the Hall element and the motor is shown in the figure. When the Hall element Hl is aligned with the N pole of the rotor magnet, IC2 outputs a high
level, VT3 is turned on and the output current goes to ground through L1 and k, and the coil generates a magnetic field to drive the rotor; when Hl is aligned with the S pole, IC2 outputs a negative level. When voltage VT4
is turned on, reverse current appears in k and Li, which also generates a magnetic field that drives the rotor to rotate. In the same way, when H2 is aligned with the S pole, or
when aligned with the N pole, a forward or reverse current will flow through L3 and L4 under the control of the ICl circuit, generating a driving magnetic field in the same direction.
- A simple magnetic switch circuit sharing
- Use your smartphone to turn on/off the power in your home
- How to make a wheeled self-balancing robot using ultrasonic sensors
- A simple door handle touch alarm circuit
- How can we make the robot move precisely on a predefined path?
- What is a RADAX motor?
- A small improvement on the ordinary refrigerator motor starting circuit
- Simple phase failure protection circuit composed of intermediate relay
- Temperature control circuit design and analysis
- Car audio system anti-theft circuit
- Simple timing control circuit
- fire smoke control circuit
- Water dispenser double sheet control circuit
- Electromagnet control circuit
- Assembly line outage monitoring circuit
- PLC transmission line automatic reclosing control circuit
- Detection and control circuit of electromagnetic stove
- Sprinkler control circuit using AC motor
- Small power electric heater temperature detection control circuit
- Small signal to large current photoelectric control circuit
