Using long time timing integrated circuit RS6445C to form intermittent oscillator
Source: InternetPublisher:吃掉星星 Keywords: oscillator integrated circuit intermittent oscillation Updated: 2021/01/26
Shown is a intermittent oscillator using a long-time timing integrated circuit RS6445C . WI and W2 divisions are used to adjust working
hours and shutdown times, both of which can be continuously adjusted within 0.5-24 hours. In the figure, two RS6445Cs can be used to make two independent
timers. The timing time of each timer is determined by the preset levels of R and C and the ④ and ⑤ pins. The timing time can be adjusted by the resistor and capacitor installed at the ① pin
- How does a series arrangement of Zener diodes affect the electrical behavior?
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- RC filter explained in detail
- Datasheet/Pinout/Technical Specifications of LMC555
- Simple Wired Spy Bug Circuit Built Based on IC741
- Diode-based clipping circuit
- Basic characteristics/working principles and application circuits of tunnel diodes
- How to build a drag racing timer circuit using a 7-segment display and discrete components
- Tutorial on building a NOT gate using BJT transistors
- High and low frequency signal generator circuit
- Patient call alarm circuit
- High reliability carrier oscillation circuit for emitter
- 32kHz transistor clock oscillator
- One of the single-junction transistor time relay circuits
- One of the simple second pulse source circuits
- Delay bedside lamp circuit with hypnotic device
- Complementary Oscillator Trigger Circuit
- Incandescent lamp flash circuit using LM3909 as oscillator
