Picture tube final video driver amplifier
Source: InternetPublisher:刘德华河北分华 Keywords: amplifier transistor resistor Updated: 2021/04/23
Shown is the complementary push-pull final video driver amplifier, which is composed of three transistors
. VT511 is the excitation amplifier.
It adopts the form of a common emitter amplifier and has the characteristics of high gain. The R signal is input from the base. Resistor R2 has a current limiting function
to prevent the base current from being too large - the amplified signal is output from the collector and then sent to the base of the complementary push-pull amplifiers
VT512 and VT513. VT512
is an NPN transistor and VT513 is a PNP transistor. , connected to form a complementary push-pull output stage, which is equivalent to two emitter followers. The bias voltage
is provided by 200 V. It has the characteristics of low output impedance and high output amplitude, and provides a driving signal for the cathode of the picture tube.
- In-depth analysis of energy losses in oscillation frequencies
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- Types and structures/characteristics/functions/implementations of smart sensors
- Make a flameless electronic candle using simple electronics and LEDs
- What is the difference between high-side and low-side resistive current sensing
- Touch circuit design and analysis
- Star finder battery indicator circuit
- Experiment and production of NE555 time base integrated circuit
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- Circuit diagram of a differential amplifier circuit
- Precision current detection amplifier design based on lithium battery detection
- How to use "virtual short" and "virtual break" to analyze op amp circuits
- Fiber optic transceiver circuit diagram
- High input impedance three op amp differential amplifier circuit diagram
- A crystal controlled local oscillator circuit diagram
- Differential bridge amplifier circuit diagram
- Analog-to-digital converter application circuit design analysis
- Broadband Difet Op Amp Circuit
- non-diode rectifier
- Pressure sensor measurement circuit
