"clairvoyance" charger circuit diagram
Source: InternetPublisher:newlandmark Keywords: Charger circuit diagram trigger Updated: 2021/10/21
The "clairvoyance" charger circuit is shown in the figure. Among them, the unidirectional thyristor VS1 is the charging current tube of the battery GB , and VS2 is used to cut off the charging current when the battery is charging. When the power is turned on for charging, relay K acts, contact 3 and contact 2 are connected, the trigger terminal of VS1 obtains the trigger voltage from R1 and VD4 and is turned on, and the rectified current charges the battery GB through VS1. When battery GB is charged to the set voltage (for example, 7.2V), VS2 is turned on, causing the potential at point A of the trigger terminal of VS1 to be much lower than the cathode potential of VS2, VS1 is cut off, and battery GB stops charging. The LED of the light-emitting tube is used for charging display. When the battery charging stops and VS2 is turned on, the LED goes out. The 6V indicator light HL is used to indicate ~220V power outage.
![“千里眼”充电器电路图](http://www.eeworld.com.cn/circuit/upload/6d95722659984f0a1a983ea9a66b5af0/ebcd13041eeb4641d5daba9b7b928092.jpg)
- How to Make a Soft Latch Circuit
- Fabrication of multi-cell lithium battery charging circuit
- Practical and convenient fax machine power supply control circuit
- Basic circuit description of adjustable voltage regulator LM317
- Use pulse width modulation to get a precise output voltage
- Charging control circuit made by solar energy
- CNC regulated power supply production
- Car power 1.5V-12V six-speed converter
- MIC4680 constant current charger
- The production of adjustable voltage-stabilized power supply composed of LM317
- Mobile phone emergency charger circuit diagram produced by LM3578
- Automatic disconnect battery charger circuit diagram
- Nickel cadmium charger circuit diagram
- Motorcycle battery charger circuit diagram
- Solid electric fence charger circuit diagram
- Simple constant current charger circuit diagram
- Voltage-limiting nickel-cadmium battery charger circuit diagram
- Fast charger circuit diagram
- Pulse charger circuit diagram with self-detection function
- Charger circuit diagram using UC3842
