Motorcycle battery charger circuit diagram
Source: InternetPublisher:赔钱虎 Keywords: Charger circuit diagram battery charger Updated: 2021/01/03
The 555 time base circuit and external resistors, capacitors and potentiometers form a thyristor trigger circuit. It is actually an astable multivibrator. After the power is turned on, C1 and C2 are charged at the same time, and the potential of pin 5 of 555 quickly rises to 2/3Vcc. At this time, the voltage on C1 is about zero, that is, the voltage of pins 2 and 6 is slightly greater than 2/3Vcc, and the output terminal 3 pin is low. The discharge tube inside the 555 is saturated, that is, pin 7 is low level, so C1 discharges, causing the potential of pins 2 and 6 to gradually drop to 1/3Vcc, and pin 3 outputs high level. This forms an oscillation, and the output of pin 3 controls the charging of the thyristor. W can adjust the charging current. When a short circuit occurs at the charging terminal, T1 is saturated, LED2 light-emitting tube lights up, the voltage at pin 4 of the forced reset terminal of 555 is approximately zero, and the trigger circuit is closed.
- Analysis of the working principle of switching regulator
- Step-down power supply for driving relays
- Recommended circuits for different power on times of LM4911
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Visible laser digital control modulation driver
- LNK304 non-isolated LED light string driver circuit
- Miniature polarity reversal power supply using MAX1721
- Dual forward converter schematic diagram
- Adjustable regulated power supply with current limiting protection
- LM317T voltage regulation adjustable circuit diagram explanation
- Mobile phone emergency charger circuit diagram produced by LM3578
- Nickel-cadmium battery charger circuit diagram
- Parallel automatic charger circuit diagram
- Making a solar cell phone charger circuit diagram
- Low voltage DC power charger circuit diagram
- Nickel-cadmium battery fast charger circuit diagram
- Simple and practical charger circuit diagram
- Micro lead-acid battery charger circuit diagram
- Philips charger circuit diagram
- Charger circuit diagram using UC3842
