Battery voltage indication circuit
Source: InternetPublisher:同住地球村 Keywords: Battery voltage LED voltage drop Updated: 2020/03/22
This circuit can be used to change the display state. If a transistor is added to the ③ pin to drive the LED , the battery will have normal voltage.
The LED does not light up, but when the battery voltage drops to a critical value, the LED starts to flash. The indicating circuit is as shown in the figure.
- The easy production of several top-quality tube preamplifiers
- Simple and practical small amplifier
- Field effect tube amplifier circuit with beautiful sound
- Make a high-quality DAC board
- Experiment of 2-in-1 single-ended Class A tube amplifier
- Stereo phono amplifier circuit with bass control composed of LM1877
- LM4903/4905 high gain audio amplifier circuit
- 1OW audio power amplifier circuit using UPC1238
- Auxiliary audio power amplifier circuit using LM4732
- Protection circuit and maintenance of household audio power amplifier
- Do you know about the YTSwitch-6 LED driver IC with high efficiency and extremely low standby power?
- Teach you a thyristor dimming LED drive power circuit design
- MAX8631X driving white LED circuit diagram
- Dark activated LED flash circuit
- LED light column drive circuit
- Three-phase phase loss alarm light circuit
- LED lighting display detection circuit with overload protection
- LM3914 drives 20 LED light-emitting columns circuit diagram
- SAA1064 serial I2C bus LED dynamic driver interface circuit diagram
- Inpatient pager circuit
