Inverter voltage starting circuit
Source: InternetPublisher:toothache Keywords: Inverter starting circuit BSP Updated: 2021/07/13
Shown is the voltage starting circuit of the inverter . Its main component is Ql, and its main function is
to provide the starting signal for the PWM control chip (TL1451CNS).
When the power is turned on to start the display, the ⑤ pin of the plug-in CNI receives the high-level start command from the control circuit. This high level is added to
the ④ pin of the start-up voltage conversion circuit QI. There are 2 transistors and bias inside Ql. element. Pin @ is the power supply terminal, pin ④ is the control signal
input terminal, and pin ② is the output terminal. When starting up, the +14 V voltage supplied by the power adapter is added to
the power supply terminal @ pin of the PWM control chip IC2 through the ②~③ pins of QI .
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Energy-saving motorcycle rectifier regulator
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Detailed explanation of 5v charger circuit diagram
- Switching power supply circuit composition and function introduction of each part
- 0.7~24V continuously adjustable current limiting power supply
- Adjustable voltage power socket
- Converting a lithium battery charging board into a constant voltage and current charger
- Adjustable voltage regulated power supply circuit
- Bone hyperplasia treatment circuit
- Electric massager circuit
- Pulse therapy circuit
- Particle clogging alarm circuit of wheat seeder
- Soil water shortage prompt circuit
- DC ammeter
- Frequency modulator composed of NE566
- Capacitive feedback oscillator circuit
- Color display circuit
- Three primary color display circuit
