Switching power supply circuit of Dongshi IDS-2000F set-top box
Source: InternetPublisher:闪电杰克 Keywords: Switching power supply circuit BSP input circuit Updated: 2021/10/31
The switching power supply circuit of Dongshi IDS-2000F set-top box is mainly composed of AC input circuit , switching oscillation circuit, secondary output circuit and
voltage stabilizing control circuit, as shown in Figure 2.63.
(1) AC input circuit
The AC input circuit is composed of switch S, fuse Fl, mutual inductance filter cl, LF1 and bridge rectifier circuit (VDI-VD4).
Its function is to filter out the interference of the AC 220V input voltage and Rectified into a DC voltage of 300V, C2 is a smoothing filter capacitor.
(2) Switching oscillation and control circuit
The switching oscillation and control circuit are integrated in Ul TEA1523P. DC 300 V
supplies power to Ul⑧ pin through the primary winding ①~② of the switching transformer Ti. The switching tube is integrated in Ul, and the positive feedback winding Pin @~④ provides power and positive feedback voltage to U1 to make Ul enter the switching
oscillation state.
(3) The attack stage of the secondary output circuit
switching transformer Ti has multiple sets of outputs, which are rectified and filtered to output +5 V, +21 V, +30 V and +3.3 V voltages respectively .
(4) Voltage stabilizing circuit
The voltage stabilizing circuit is connected to the +5V output circuit. Rl4 and R11 form a voltage dividing circuit. U3 is the error detection and error amplifier. It feeds the error
signal back to the ④ pin of Ul through the optocoupler. Control the oscillation output of Ul.
- The basic principles of power supply design. What are the key components of a power supply?
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Basic circuit description of adjustable voltage regulator LM317
- Recommended circuits for different power on times of LM4911
- Current/voltage conversion circuit using current converter
- Power supply circuit that can reduce LM317 ripple
- Integrated regulated power supply with continuously adjustable output voltage
- Excellent performance household inverter power supply circuit
- Electric massager circuit
- Pulse therapy circuit
- Egg warming circuit
- Rice mill circuit
- Poultry warming temperature control circuit
- Junction field effect transistor mixer circuit
- collector amplitude modulation circuit
- Capacitive feedback oscillator circuit
- Three primary color display circuit
