Switching power supply circuit using TEA2260-61 and TEA5170 combination
Source: InternetPublisher:拿铁三分糖 Keywords: TE switching power supply circuit oscillation Updated: 2020/04/14
Shown is a switching power supply circuit using a combination of TEA2260/61 and TEA5170 . 'rEA2260/61 is a switching and oscillation voltage stabilizing
control integrated circuit pin output pulse excitation signal , which is added to the base of the switching transistor to cause the switching tube to output switching pulses. The secondary TEA5170
outputs horizontal pulses from the @ pin under the stimulation of the horizontal synchronization pulse, and provides synchronization pulses to the TE A2260/61@ pin through the pulse transformer, so that the oscillation
of the switching power supply is the same as the horizontal frequency.
- Benefits of Wide Bandgap Technology for Power Converters
- Fabrication of multi-cell lithium battery charging circuit
- Energy-saving motorcycle rectifier regulator
- Op amp power supply decoupling bypass measures
- Transformerless AC-DC constant current LED driver circuit
- Constant current LED lamp driver circuit with soft start and anti-shock
- How to use SBR to improve power conversion efficiency
- Current/voltage conversion circuit using current converter
- Car power 1.5V-12V six-speed converter
- Mc34063 MP3 Switching Charger
- Importance of Voltage Supervisors and Output Topology Selection
- High voltage series switching power supply circuit
- Power circuit of STR5412
- Oscillation process of multivibrator b
- Switching regulated switching power supply circuit
- Voltage Controlled ECL (Emitter Coupled Logic) Integrated Circuit Crystal Oscillator Generator Circuit
- Half-bridge pulse width modulation switching power supply circuit
- Experimental switching power supply circuit
- 5V, 50A building block switching power supply circuit
- Full-bridge switching power supply circuit main circuit
