Internal functional block diagram and external related circuits of ICE3DS01-G
Source: InternetPublisher:武林萌主 Keywords: switching transformer Updated: 2021/10/15
The internal functional block diagram and external related circuits of the switching integrated circuit N901 ( ICE 3DS01/G) are as shown in the figure.
The DC voltage formed by the rectification of the AC input is added to the drain D of the switching field effect transistor through the primary buffer coil of the switching transformer. At the same time Provide starting voltage for the @ pin of N901
. When N901 starts, it also starts the switching tube. The positive feedback voltage generated by the switching transformer is added to the ⑦ pin of N901. N901 enters the oscillation state. The @ pin outputs switching pulses and the switching power supply outputs +12 V. The negative feedback signal formed by
the error detection circuit is photoelectrically coupled. The detector is sent to the ② pin of N901
, the @ pin is the current detection input terminal, and the ① pin is the soft start capacitor terminal.
- How about the boost converter TPS61299?
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Driving circuit of switching power supply field effect tube
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Op amp power supply decoupling bypass measures
- Visible laser digital control modulation driver
- Low cost and high performance LED constant current power supply
- Dual forward converter schematic diagram
- Dynamic power supply for power amplifier controlled by thyristor
- Converting a lithium battery charging board into a constant voltage and current charger
- Laser power circuit
- High current (4A) switching regulator integrated circuit L296 outputs 5.1 to 40V
- Power supply circuit with multiple outputs (MAX1902)
- FGDF-3 three-phase low-temperature iron-plated power supply circuit
- Super Class A power amplifier power circuit
- Single LTC power circuit
- Common power circuits and applications 07
- AC-DC conversion power supply-inverter power supply circuit
- Nine-speed adjustable DC power circuit
- 6.3V, 270V, 300V DC power supply circuit
