Application circuit to increase output voltage
Source: InternetPublisher:蓝猫淘气 Keywords: Application circuit output voltage BSP three-terminal voltage regulator Updated: 2020/02/22
At present, the highest output voltage level of t three-terminal voltage regulator is 24 V. When an output voltage greater than 24 V is required, the circuit for increasing the output voltage
shown in Figure 2-23 can be used .
- A very convenient small power supply circuit to share
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Recommended circuits for different power on times of LM4911
- Visible laser digital control modulation driver
- Constant current LED lamp driver circuit with soft start and anti-shock
- LED Driver ZD1680
- Charging control circuit made by solar energy
- LM317 regulated power supply
- Design of electric vehicle charger
- High-efficiency speaker circuit for rural stage
- Chicken supplementary light to increase egg production rate circuit
- Fish farming thermostatic control circuit
- Junction field effect transistor mixer circuit
- Frequency modulator composed of NE566
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- common emitter amplifier circuit
- Color display circuit
- Various signal generator circuits
- Sine wave signal generator circuit
