Basic regulating tube voltage stabilizing circuit b
Source: InternetPublisher:闪电杰克 Keywords: Voltage stabilizing circuit BSP transistor output voltage Updated: 2021/08/04
The so-called series voltage stabilizing circuit is to insert a triode in series between the input DC voltage and the load . Its function is that when q or RL
changes, causing the output voltage Uo to change, the UcP of the triode will also follow through some form of feedback. changes, thereby adjusting the output voltage
to keep the output voltage basically stable. Since the transistor connected in series plays a regulating role, it is called a regulating tube.
Figure (a) shows the basic regulating tube voltage stabilizing circuit . Transistor VI' in the figure is an adjustment tube. In order to analyze its voltage stabilization principle, we
change the circuit shown in Figure (a) into the form shown in Figure (b). At this time we can clearly see that it is essentially based on the circuit shown in the figure. It is composed of an emitter follower. According to the characteristics of the circuit, it can be seen that 乩 and Uz are in a following relationship. Therefore, as long as
the voltage Uz of the voltage regulator tube remains stable, 乩 can also be basically stable when alum and IL change within a certain range. The outstanding feature after adding the medullary device
is the enhanced load carrying capacity.
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- Introduction and principle analysis of switching regulated power supply
- Basic circuit description of adjustable voltage regulator LM317
- LED rechargeable flashlight circuit diagram
- Detailed explanation of 5v charger circuit diagram
- Dual forward converter schematic diagram
- A small and easy-to-make fast charger
- UC3842 Electric Vehicle Charger
- MIC4680 constant current charger
- A low-cost, high-reliability battery charger for electric vehicles
- Inpatient pager circuit
- Fish pond oxygenation reminder circuit
- Egg warming circuit
- Agricultural small tractor lighting circuit
- Domestic KD8041 integrated phase locked loop
- Diode Balanced Mixer Circuit
- Proportional frequency discriminator circuit
- Wien bridge oscillator circuit
- Three primary color display circuit
- Home appliance repair signal generator circuit
