Inverter circuit in a typical LCD display (OZ965)
Source: InternetPublisher:elleny Keywords: LCD display inverter circuit step-up transformer BSP Updated: 2020/06/02
Shown is the inverter circuit in a typical LCD display
. This circuit is mainly composed of control chip 02965, driving field effect
transistor U2, step-up transformer , backlight socket and related circuit parts.
The 5v DC voltage provides DC voltage to the @ pin of the control chip UI (02965) after passing through the plug-in Jl; at the same time,
after passing through the filter cell C2, it supplies power to the driving field effect transistor Ul and the boost transformer; the startup control signal (ENA) passes through the plug-in Jl It is sent to the @ pin of the control chip. After
the inverter circuit is started, two PWM pulse signals with opposite phases are output by the @ pin and @ pin of Ul. They are amplified by the driving field effect transistor Ul and sent
to the step-up transformer . The voltage transformer increases the pulse voltage to about 800V, and supplies power to the backlight tube through the backlight socket.
- A very convenient small power supply circuit to share
- 220V Remote Load Monitor
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Recommended circuits for different power on times of LM4911
- Visible laser digital control modulation driver
- Driving circuit that controls LED brightness using PWM signal
- Switching power supply circuit composition and function introduction of each part
- Electric bicycle battery charger circuit
- Converting a lithium battery charging board into a constant voltage and current charger
- Homemade Electric Bike Fast Charger
- Motor forward and reverse control wiring diagram (2)
- electromagnetic field sensor
- Bone hyperplasia treatment circuit
- Electric massager circuit
- Fish farming thermostatic control circuit
- Farmland irrigation automatic control circuit b
- Junction field effect transistor mixer circuit
- Amplitude modulation circuit composed of MC1496
- Wien bridge oscillator circuit
- Broadband high frequency power amplifier circuit
