Long delay constant current charging circuit
Source: InternetPublisher:ghaytweyhtoo Keywords: constant current charging circuit CD4541 power supply Updated: 2020/10/23
Shown is a long-delay constant current charging circuit using CD4541 , which is suitable for charging Ni-Cd batteries. When the power is turned on, the CD4541@ pin outputs a high level to turn on the electronic switch TWH8778, and the constant current
source
composed of LM317 charges the battery. After
more than ten hours, the CD4541 output becomes low level. TWH8778 cuts off the power supply and charging ends.
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- 220V Remote Load Monitor
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Single-power supply circuit for ISO122P/ISO124
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Switching power supply circuit composition and function introduction of each part
- Converting a lithium battery charging board into a constant voltage and current charger
- Car Audio Power Supply
- Internal structure block diagram of CD4541
- Simple automatic power off battery charging circuit
- Charging circuit personal working principle diagram
- One of the non-polar battery charging circuits
- Simple programmable charging circuit
- General circuit diagram of a simple battery automatic constant current charging circuit
- Repeater charging circuit
- Nickel cadmium battery charging circuit
- Charging circuit diagram with automatic circuit breaking
- Simple battery charging circuit diagram
