Internal functional block diagram of NCP5201
Source: InternetPublisher:三岁就很酷 Keywords: NCP field effect transistor Updated: 2021/09/21
NCP 520】There are two sets of PWM signal generating circuits in the chip . One set outputs two PWM signals with opposite phases from the @ pin and the @ pin, which
are respectively added to the gates of the three field effect transistors , so that the two sets of field effect transistors alternately conduct. The battery's power supply voltage is turned into a pulse voltage,
and then filtered by L2 and COUT to become a +2.5 V voltage to power the memory. At the same time, the +2.5 V power supply is added to the @ pin of the chip, and there
is a second set of PWM signal generating circuits and two field effect transistors inside the chip. These two field effect transistors turn the 2.5 V voltage into a pulse signal,
which is output by the ⑥ pin of the chip . After filtering by C14, C15, and C16, it outputs a 1.25 V DC voltage to power the circuit in the memory .
- The basic principles of power supply design. What are the key components of a power supply?
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- Constant current LED lamp driver circuit with soft start and anti-shock
- Voltage-current converter constructed with XTR110
- Dynamic power supply for power amplifier controlled by thyristor
- A small and easy-to-make fast charger
- Car power 1.5V-12V six-speed converter
- UC3842 Electric Vehicle Charger
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Power circuit of STR5412
- Portable device charging power circuit design
- Power circuit of LBO-522 dual trace oscilloscope
- Computer memory power supply circuit (NCP5201)
- FGDF-3 three-phase low-temperature iron-plated power supply circuit
- Karaoke light controller circuit (1)
- DC/DC power supply circuit diagram controlled by NCP1562
- NCP5603 driving LED typical application circuit
- Field Effect Transistor Dual Trace Oscilloscope Switch
- Single supply gallium arsenide field effect transistor power amplifier
