Network card power supply circuit using SC1470 control chip
Source: InternetPublisher:3228 Keywords: Control chip power supply circuit PWM switch Updated: 2020/02/26
Shown is the network card power supply circuit using the SC1470 control chip . The circuit is
composed of an SC1470 and two switching field effect transistors. SC1470 is a control circuit that generates PWM pulse signals. When working, pin ⑨ and pin @ respectively output two
PWM pulse signals with opposite phases. The QI and Q2 field effect transistors work alternately under the action of the PWM signal, turning the DC power supply of the battery into switching pulses. After LC filtering, they output a 1.2 V DC voltage to power Aka.
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- Schematic diagram of car cigarette lighter to USB power port
- 220V Remote Load Monitor
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Dynamic power supply for power amplifier controlled by thyristor
- Adjustable voltage power socket
- MIC4680 constant current charger
- Production of backup power supply for cordless phone
- Battery powered switching circuit diagram
- Collection of switching mode power supply circuit diagrams, please collect it quickly
- Classification analysis of PWM control
- Rice cooker power supply circuit
- Power supply circuit for computer motherboard using RT9173-A chip
- Structure and working principle of 2-phase PWM circuit
- Application of TL494 as current regulator
- LM621 brushless DC motor commutation circuit-three-phase full-wave drive circuit
- 25W single chip audio class D power amplifier IC-TDA7482
- High voltage pulse width modulation (PWM) LED driver controller circuit diagram analysis
- High voltage PWM switching power supply circuit
