LM621 brushless DC motor commutation circuit-three-phase full-wave drive circuit
Source: InternetPublisher:萌面大虾 Keywords: Brushless DC motor drive circuit PWM Updated: 2021/01/25
In the three-phase bipolar drive circuit
, external
PNP and NPN transistors form a three-phase inverter bridge, and the base drive is equipped with a current limiting resistor. The dead time here
is connected to the 4.8 design. The circuit is also equipped with over-current protection. When the current exceeds the predetermined
limit value, pin 17 acts to stop the motor. The speed control PWM signal
is input from the MAG toe.
- Car ice warning circuit sharing
- Peripheral circuit of automotive motor controller power supply chip
- What are the challenges in designing a permanent magnet linear generator?
- Introduction to the internal structure of the Delta winding motor
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Design and analysis of the principle of automatic power-off switch during power outage
- Electric vehicle battery charging protection circuit
- PIC microcontroller controlled remote anti-theft alarm circuit
- Precious home appliance anti-theft alarm
- Block diagram of multi-channel surround stereo power amplifier circuit using digital power amplification
- Switching regulated power supply circuit
- Car window control circuit
- Lithium battery charger circuit
- Charging circuits for various types of batteries
- Internal functional block diagram of SC1486 power management chip
- Digital camera 5-channel power supply MAX1565
- Open loop speed control
- High voltage pulse width modulation (PWM) LED driver controller circuit diagram analysis
- High voltage PWM switching power supply circuit
