Digital camera 5-channel power supply MAX1565
Source: InternetPublisher:小胖友 Keywords: Digital camera power supply PWM DC voltage Updated: 2021/08/05
Shown is the MAX1565 5-channel power supply for a digital camera . As can be seen from the figure, the chip is equipped with multi-channel pulse width signal generation and
control circuits. Different voltage stabilization methods are used according to the DC voltage value and current required by the digital camera . The DL3 pin of the chip outputs a 71 voltage PWM
drive signal - making the external field effect transistor work in the switching state. A PWM pulse current is formed in the primary winding of the switching transformer Tl, and is output +15 respectively after the secondary rectification and filtering of the switching
transformer Tl. V (20 mA) and 7.5 V (20 rnA). DL1 and DL2 terminals output
boosted PWM signals, which output +5 V and +15 V voltages through the field effect switch tube and rectifier filter circuit respectively. There are also two sets of PWM circuits,
which convert the DC voltage into switching pulses through their respective sets of switching field effect transistors. Then the DC voltage is output through the filter circuit to
power circuits such as CPU.
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- 220V Remote Load Monitor
- LED Driver ZD1680
- Current/voltage conversion circuit using current converter
- 3~15V 10A adjustable voltage regulated power supply
- Adjustable voltage regulated power supply circuit
- Practical constant current charger-----Constant current charger
- MAX1811 Lithium Battery Charger Production
- A low-cost, high-reliability battery charger for electric vehicles
- A switching device used in the industrial field, the working principle and classification of high-frequency inverters
- How current transformer works
- Dual adjustable power circuit
- LCD backlight power supply circuit
- Laptop chip power supply circuit
- Analog PWM connection diagram using zps-101 interface
- 5V, 0.5A power supply circuit
- PWM circuit with clock
- Simple PWM DC motor speed regulation circuit
- Energy consumption braking circuit of PWM frequency converter
