DDR memory power supply circuit
Source: InternetPublisher:已注销 Keywords: DDR power supply circuit switch Updated: 2020/04/30
Shown is the DDR memory power supply circuit in a notebook computer . The power control chip in this circuit is MAX8632.
The VDD of the chip is the Sv power supply terminal (detection point 1). The DC power supply voltage of the battery is between 4.5 V and 2.8 V. The voltage is added to the drain of the switching field effect
transistor Ql, and the DH and DL of the power control chip respectively output a pair of PWM pulse signals with opposite phases. The signals
are added to . Under the action of the PWM pulses, Q1, Q2 works alternately, changing the DC voltage of the battery into a switching voltage, and then
outputs a 2.5 V voltage after LC filtering to power the memory circuit.
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- In-depth analysis of DC-AC converter inverter
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Dual forward converter schematic diagram
- 0.7~24V continuously adjustable current limiting power supply
- Design of electric vehicle charger
- Production of backup power supply for cordless phone
- Practical constant current charger-----Constant current charger
- MAX1811 Lithium Battery Charger Production
- Homemade home inverter circuit diagram
- Causes of inductor whistling in DC/DC circuits and related solutions
- Power phase failure display circuit
- Light touch alarm circuit
- Electric iron power saving circuit
- Paper tension control circuit
- LCD backlight power supply circuit
- Sony laptop memory power supply circuit (SC486)
- Laptop chip power supply circuit
- Power supply circuit with self-starting function
- 5V power supply circuit with temporary backup stable power supply
