FGDF-3 three-phase low-temperature iron-plated power supply trigger circuit
Source: InternetPublisher:难得正经 Keywords: Power supply trigger circuit MDASH Updated: 2021/08/17
The KGDF-3 low-temperature iron-plated power supply unit has all the characteristics of a single-phase low-temperature iron-plated power supply unit. In addition, due to the use of
three-phase power supply, the grid load can be evenly distributed. Technical parameters of
the power supply device: AC input voltage, three-phase 380V, 50Hz: DC output voltage, forward DC
-16V (continuously adjustable), reverse DC 0~16V (continuously adjustable); rated output current, AC symmetrical Output ±50A,
asymmetrical current output 0~±500A, DC pole-changing output 0~+1OOOA, forward DC 0—+1OOOA, reverse DC
~-1000A, forward time control 1~30s (1~22s) , reverse time control 0.5—2s (0.5—ls).
The actual adjustable numbers are in parentheses above.
- Schematic diagram of car cigarette lighter to USB power port
- In-depth analysis of DC-AC converter inverter
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- ISO113 circuit that can reduce power consumption
- Basic connection circuit of signal and power supply composed of ISOll3
- Op amp power supply decoupling bypass measures
- Simple and practical LED lamp driving circuit
- Electric bicycle battery charger circuit
- Adjustable voltage regulated power supply circuit
- MAX1811 Lithium Battery Charger Production
- What is a low EMI power supply? It’s worth collecting!
- Why is the scrapped volume of electric vehicle batteries so much higher than predicted?
- To optimize battery charging, Apple introduces new power management features in macOS
- Variable gain preamplifier circuit
- Staircase wave signal generator circuit
- Simple buzzer circuit one a
- Multiple sets of light-emitting diode lantern chain circuits with different flashing frequencies a
- A HI-FI active integrated speaker 01
- Open loop speed control
- JS88 holiday lights catch yo integrated circuit
