35W half-wave resistor-capacitor phase-shift trigger actuation control circuit
Source: InternetPublisher:通通 Keywords: Control circuit resistance-capacitance phase-shift trigger dynamic control Updated: 2021/08/27
35W half-wave resistance-capacitance phase-shift trigger actuation control circuit
In automatic or semi-automatic arc welding equipment, in order to control the transportation of welding wire and the movement of the welding car, a drag control circuit must be used to
meet the requirements of the welding process.
(1) 35W half-wave resistor phase-shift trigger drag control circuit
The circuit is as shown in the figure. The motor uses a 35W DC servo motor. Through the voltage divider composed of potentiometers RPi, RPz and
RP4, the feedback voltage is taken out from RP4 and superimposed on the resistor-capacitor phase-shifted AC voltage to form a strong negative feedback
to achieve the purpose of stable speed regulation. Adjust RP3 to change the armature voltage to achieve speed regulation.
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Constant current LED lamp driver circuit with soft start and anti-shock
- Dual forward converter schematic diagram
- Charging control circuit made by solar energy
- Dynamic power supply for power amplifier controlled by thyristor
- CNC regulated power supply production
- Car power 1.5V-12V six-speed converter
- 0.7~24V continuously adjustable current limiting power supply
- UC3842 Electric Vehicle Charger
- Converting a lithium battery charging board into a constant voltage and current charger
- Satellite receiving antenna follow-up control circuit diagram
- Differential amplifier emitter negative feedback gain control circuit
- fire smoke control circuit
- Water and electricity saving infrared control circuit
- Photocell amplification control circuit
- Paper tension control circuit
- Chandelier control circuit
- Schematic diagram of motor PLC control circuit
- Use time relay to automatically switch Y-△ starting control circuit
- Frequency sensitive rheostat starting control
