BX1 series AC arc welding machine circuit
Source: InternetPublisher:石榴姐 Keywords: Arc welding machine electromechanical Updated: 2021/02/19
The BX1 series AC arc welding machine is a three-core single-phase magnetic shunt moving iron transformer structure. The circuit is shown in Figure 9-1. There are two types of
current adjustment: coarse adjustment and fine adjustment. For coarse adjustment, you can replace the connecting piece on the output terminal board (when terminals 1 and 2 are connected, it is L
connection method, when terminals 2 and 3 are connected, it is II connection method). Fine adjustment is to turn the handle in the middle of the welding machine to change the position of the moving iron core, that is, to change
the size of the magnetic leakage shunt, thereby obtaining uniform current regulation.
- 5 Converter Topologies for Integrated Solar and Storage Systems
- How to Make a Soft Latch Circuit
- What kind of circuit is a voltage regulator circuit?
- Basic circuit description of adjustable voltage regulator LM317
- Use pulse width modulation to get a precise output voltage
- Driving circuit that controls LED brightness using PWM signal
- Adjustable regulated power supply with current limiting protection
- USB power socket using the car battery
- Converting a lithium battery charging board into a constant voltage and current charger
- Adjustable voltage regulated power supply circuit
- Physiotherapy ventilator circuit
- Fan motor starting circuit diagram
- Schematic diagram of current direction and coil rotation direction of DC brush motor
- Three-phase induction motor circuit schematic using starting compensator
- Digital camera-DV machine power supply circuit
- GZ-600 argon arc welding machine circuit-02
- BX2 series AC arc welding machine circuit d
- BX2 series AC arc welding machine circuit a
- KGCA-15-0-165 thyristor charger circuit
- GCA-30 (0-36, 0-72) silicon rectifier charger circuit
