Multifunctional conductivity tester circuit
Source: InternetPublisher:已注销 Keywords: Tester electrode indicator light Updated: 2021/02/21
![Multifunctional conductivity<strong>Tester</strong><strong>Circuits</strong>](http://www.eeworld.com.cn/circuit/upload/9c1e600a11c00f70696aee55190978e6/e2fdfb98697a4469e249deb0df3b62a9.jpg)
The circuit of the multifunctional conductivity tester is composed of a detection electrode , a resistor divider, a buffer circuit and a two-color diode, as shown in the figure. The detection electrode can sense the resistance of the object being measured, and control the two-color light-emitting diode to emit light according to the resistance of the object being measured. When the detection electrode senses that the resistance of the object being measured is greater than 300kΩ and less than 1000kΩ, the green indicator light turns on; when it senses that the resistance of the object being measured is less than 300kΩ, the red indicator light turns on, making the two colors synthesize into an orange-red light; it senses that the resistance of the object being measured is greater than 1000kΩ , the two-color indicator lights VL3 and V⒕ do not light up. Adjusting the potentiometer RP can change the sensing range of the detection electrode .
- How to Make a Soft Latch Circuit
- In-depth analysis of DC-AC converter inverter
- Energy-saving motorcycle rectifier regulator
- Step-down power supply for driving relays
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Transformerless AC-DC constant current LED driver circuit
- How to use SBR to improve power conversion efficiency
- Dynamic power supply for power amplifier controlled by thyristor
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Car turn indicator circuit
- Flower pot water shortage alarm circuit
- Capacitor step-down indicator light circuit
- One of the regulated power supply overload indication circuits
- Thyristor type liquid level automatic control circuit 2 (withdrawable type)
- Practical emergency light circuit (3)
- Capacitor start, battery powered indicator light circuit
- 555 digital multimeter additional frequency tester circuit diagram
- FD-2 type redox potentiometer electrode application circuit
