Battery discharge status indication circuit 5
Source: InternetPublisher:两手空空 Keywords: battery battery discharge BSP Updated: 2020/04/24
The right side of the dotted line in the figure is the simplest series-connected transistor regulated power supply. Connect the anode of the voltage regulator tube
vs to the base of the indicator transistor VTz, which can be used to monitor the battery voltage.
When the battery is discharged to a voltage of Uz+0.7V (where U; is the voltage stabilization value of the voltage regulator tube vs), the transistor VT2 is cut off, VTi is turned on, and the light-emitting diode VL lights up, indicating that the battery
needs to be charged or replaced. .
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Driving circuit that controls LED brightness using PWM signal
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- LED rechargeable flashlight circuit diagram
- LNK304 non-isolated LED light string driver circuit
- Dynamic power supply for power amplifier controlled by thyristor
- Adjustable regulated power supply with current limiting protection
- LM317 regulated power supply
- Electric bicycle battery charger circuit
- Homemade home inverter circuit diagram
- Motor overcurrent protection circuit
- stuttering correction circuit
- Smoking Cessation Circuit
- Domestic KD8041 integrated phase locked loop
- Integrated synchronous detector composed of analog multiplier MC1596
- collector amplitude modulation circuit
- Amplitude modulation circuit composed of MC1496
- Wien bridge oscillator circuit
- Capacitive feedback oscillator circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
