Battery discharge status indication circuit 4
Source: InternetPublisher:super_star Keywords: battery battery discharge BSP Updated: 2020/04/07
It can be used as a battery . When the battery is
fully charged, pin 6 of operational amplifier A outputs high level, and the light-emitting diode VL goes out. When the battery voltage is
insufficient, VL lights up.
By adjusting the potentiometer RP, the size of the sampling voltage can be changed to monitor how low the battery drops before VL goes out
- Analysis of the working principle of switching regulator
- Recommended circuits for different power on times of LM4911
- Op amp power supply decoupling bypass measures
- Driving circuit that controls LED brightness using PWM signal
- A small and easy-to-make fast charger
- Homemade low-power UPS
- Electric bicycle battery charger circuit
- The production of adjustable voltage-stabilized power supply composed of LM317
- Practical constant current charger-----Constant current charger
- Homemade home inverter circuit diagram
- Motor overcurrent protection circuit
- stuttering correction circuit
- Smoking Cessation Circuit
- Domestic KD8041 integrated phase locked loop
- Integrated synchronous detector composed of analog multiplier MC1596
- collector amplitude modulation circuit
- Amplitude modulation circuit composed of MC1496
- Wien bridge oscillator circuit
- Capacitive feedback oscillator circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
