One of the battery discharge status indication circuits
Source: InternetPublisher:子丑寅卯 Keywords: battery battery discharge BSP Updated: 2020/03/15
It can be used for voltage monitoring of batteries of 1.8V and above, so as to know when
the battery needs to be charged or replaced.
The control voltage threshold can be changed by changing the corresponding resistors R1, R2 and R according to the following formula. The resistance value is adjusted.
When Ri is wrong, R2 is on, R3 is on
, U is the battery voltage, V.
- Analysis of the working principle of switching regulator
- 220V Remote Load Monitor
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Parallel DC regulated power supply circuit diagram
- Principles and precautions of active discharge circuit
- How to use SBR to improve power conversion efficiency
- Adjustable voltage power socket
- Electric bicycle battery charger circuit
- Adjustable voltage regulated power supply circuit
- Motor overcurrent protection circuit
- stuttering correction circuit
- Smoking Cessation Circuit
- Domestic KD8041 integrated phase locked loop
- Integrated synchronous detector composed of analog multiplier MC1596
- collector amplitude modulation circuit
- Amplitude modulation circuit composed of MC1496
- Wien bridge oscillator circuit
- Capacitive feedback oscillator circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
