Thyristor fast constant current charger circuit
Source: InternetPublisher:zht24 Keywords: Charger constant current thyristor electromechanical Updated: 2021/08/10
It can quickly charge the nickel-cadmium battery with constant current, and can automatically cut off the power after being fully charged.
A constant current circuit composed of the AN7805 three-terminal fixed integrated voltage regulator and resistor R3 is used to charge the battery ( the constant current value is approximately equal to
the nominal voltage regulation value of the three-terminal fixed integrated voltage regulator divided by R3). When charging, press the button SB, the bidirectional thyristor V is turned on, and
the charging indicator light VL lights up. When the battery is fully charged (reaches 3V), by pre-setting the potentiometer RP, the transistor VT
is turned on, VL is turned off, the bidirectional thyristor V is turned off, the power supply is automatically cut off, and charging is stopped.
- Analysis of the working principle of switching regulator
- The basic principles of power supply design. What are the key components of a power supply?
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- ISO113 circuit that can reduce power consumption
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Adjustable regulated power supply with current limiting protection
- LM317T voltage regulation adjustable circuit diagram explanation
- Detailed explanation of mobile phone charger circuit diagram
- LED backlight driver module design circuit
- Battery constant current charging circuit
- One of the non-polar battery charging circuits
- Module constant current port wiring
- Suppression of the influence of power supply voltage waveform (b)
- Display circuit using constant current tube as steady current tube
- Production of high-quality active two-way constant current power amplifier 02
- Balanced constant current output circuit with good balance and wide current selection range
- Switching constant current charging circuit diagram
- SCR constant current and constant voltage charger
