75kW asynchronous motor synchronous operation main circuit and control circuit
Source: InternetPublisher:张小哥 Keywords: Asynchronous motor control circuit main circuit BSP Updated: 2021/01/15
When the rotor of a wound asynchronous motor is started, DC current is supplied to pull the rotor into synchronization and
run as a synchronous motor, which is called asynchronous motor synchronization.
The synchronous operation of asynchronous motors can reduce the reactive power loss of the motors, and can even feed back reactive power to the power grid
, improve the voltage quality of the power grid, and save electric energy. The lower the motor load rate and the larger the capacity, the better the economic effect.
(1) Main circuit and control circuit
The circuit is as shown in the figure. The rotor of the wound asynchronous motor
uses thyristor excitation, and the excitation current can be
automatically adjusted as needed to achieve automatic and stable operation. The motor is started by connecting a frequency-sensitive rheostat in series with the rotor winding.
- DIY a portable Bluetooth speaker
- Low noise hybrid headphone amplifier
- Double tuned amplifiera
- Lebao CFXB15-6 to CFXB40-6, CFXB40-2HD thermal insulation electronic multi-purpose rice cooker circuit diagram
- Rice cooker circuit drawing 26_electronic type
- DC detection automatic watering controller circuit
- Transformer AC contactor DC operation circuit c
- Panasonic NR-172TA-X refrigerator circuit
- Universal inverter deceleration braking circuit
- AM radio automatic search and trigger circuit
- Excellent performance household inverter power supply circuit
- Smoking Cessation Circuit
- Physiotherapy ventilator circuit
- Rural fish farming control circuit
- collector amplitude modulation circuit
- Series crystal oscillator
- Inductive feedback oscillator circuit
- OTL low frequency power amplifier circuit
- Voltage controlled power supply second-order high-pass filter circuit
- High and low frequency signal generator circuit
