Bridge drive circuit made of 555 integrated circuit
Source: InternetPublisher:Lemontree Keywords: Drive circuit Updated: 2024/10/08
As shown in Figure 6, it is composed of two 555 time base circuits (IC1, IC2), and the motor M is connected between the two output terminals of IC1 and IC2. The output stage circuits of IC1 and IC2 are marked in Figure 6, Vi and Vi2 are control signals, and Vo1 and Vo2 are output signals. When Vi1=0 and Vi2=1, the upper transistor of IC1 and the lower transistor of IC2 are turned on, Vo1=VCC, Vi2=0, and the motor M rotates forward. When Vi1=1 and Vi2=0, the lower transistor of ICl and the upper transistor of IC2 are turned on, Vo1=0, Vo2=Vcc, and the motor M rotates reversely. The bridge drive circuit can easily realize the forward and reverse control of the motor.
- Analysis of the working principle of the sound and light controlled delay switch circuit
- Tutorial on making your own remote-controlled robotic arm
- Use your smartphone to turn on/off the power in your home
- JDB-LQ-TQ/2 motor full voltage starting circuit
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- One-way rotation circuit of motor controlled by contactor
- IGBT modules block overcurrent by controlling the gate
- Hydraulic control circuit design and analysis
- Do-it-yourself trial production of phase failure protection device
- Home wireless burglar alarm circuit
- Electronic rhythm control circuit
- Schematic diagram of motor PLC control circuit
- PLC transmission line automatic reclosing control circuit
- Relay control circuitb
- Relay control circuit a
- Photoelectric detection output control circuit
- DC motor forward and reverse control circuit
- Button type electronic volume control circuit
- Basic structure of power factor control circuit
- Wide input range non-synchronous voltage mode control circuit
