Wiring of zinc oxide arrester with series gap four-star connection
Source: InternetPublisher:红水杯 Keywords: Wiring arrester series connection BSP Updated: 2021/12/14
2) The wiring operation practice of zinc oxide lightning arrester with series gap four-star connection method
shows that the protection in Figure 20-43 (a) is not ideal. In order to more effectively protect the high-voltage motor from
the hazards of operating overvoltage, it can be used Zinc oxide arrester protection with four-star connection in series gap. Its wiring is
shown in the figure. It can well protect the insulation between the relative phases and the relative ground of the motor.
- The basic principles of power supply design. What are the key components of a power supply?
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- How to Make a Soft Latch Circuit
- LED Driver ZD1680
- Boost drive circuit composed of RT8450
- A simple positive and negative power supply circuit
- LM317 regulated power supply
- Design of electric vehicle charger
- Converting a lithium battery charging board into a constant voltage and current charger
- The production of adjustable voltage-stabilized power supply composed of LM317
- Rice mill circuit
- Poultry warming temperature control circuit
- Soil water shortage prompt circuit
- Double detuned loop frequency discriminator circuit
- Frequency modulator composed of NE566
- Diode balanced amplitude modulation circuit
- Audio function generator composed of ICL8038
- common emitter amplifier circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Power phase sequence display circuit
