Odd-frequency counter with symmetrical output waveform (μL9020)
Source: InternetPublisher:赔钱虎 Keywords: counter Updated: 2024/10/12
As shown in the figure, the frequency divider circuit can be triggered for sine waves, square waves or positive pulses as long as the peak value reaches between 0.5 and 5V. The operating frequency of the circuit can reach 40MHz. The input signal of the frequency divider drives the J-K trigger through the limiting amplifier Q1 and finally outputs through the buffer Q2. The transistor Q1 is to provide an appropriate trigger level for the first stage of frequency division. When driven at a high level, the capacitor C1 can play a current limiting role. If the driving level is low, the capacity of C1 can be increased to increase the triggering ability. The output stage Q2 can prevent the frequency divider from being affected by the capacitive load.
- What is a FinFET? What are the advantages and disadvantages of FinFET?
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- Principle set of zero-crossing detection circuit advantages and disadvantages
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- Basic characteristics/working principles and application circuits of tunnel diodes
- How does RCCB work?
- Important things to know about PCB routing and how to design the right routing for your PCB
- Ceramic filter structure/working principle/characteristics/application
- Star finder battery indicator circuit
- LED Night Light
- Counter composed of 4 T flip-flops
- traffic light circuit
- Control ladder diagram of advance and retreat mechanism
- Time accumulation circuit using 555 time base integrated circuit
- Staircase wave signal generation circuit composed of ring counter and digital-to-analog converter
- High voltage Geiger counter power circuit
- Phone call counter
- Cycle counter display
- Programmable divider to control counter reset (1)
- Programmable divider to control counter reset (2)
