A low-cost electronic alarm circuit diagram
Source: InternetPublisher:赔钱虎 Keywords: Relay alarm circuit siren Updated: 2024/06/07
This is a low cost, simple yet powerful electronic siren that is powered by only a 9V battery. This circuit can provide the final circuit block module in an alarm circuit using a relay to activate it.
How a Simple Electronic Siren Works
When the switch is pressed, C3 charges through R4 with a time constant of 0.47 seconds. When the switch is released, C3 begins to discharge more slowly through R7 and R3 with a time constant of about 5 seconds. The op amp is set up as a voltage controlled oscillator. The control voltage in this simple electronic siren circuit is the exponential rise and fall of the voltage as C3 charges and discharges.
When the output of the oscillator (pin 7) goes low, the charge remaining on C1 keeps pin 5 below the switch point. The current through R7 is proportional to the control voltage on C3. This current discharges C1, causing the voltage on pin 5 to rise toward the switch point at a rate proportional to the voltage on C3. When the switch point is reached, pin 7 switches high and initially pulls pin 6 high through C1. This causes the op amp to temporarily hard start. But C3 quickly charges through D2, causing the voltage on pin 5 to drop below the switch point and causing the op amp to shut down again.
The positive pulse output of the op amp places a fixed amount of charge into C2, slightly raising the potential at pin 6. This causes the potential at pin 6 to rise and helps the op amp turn off quickly. Also, R5 and C2 delay the rise at pin 6 long enough to get a good output pulse.
The cycle then repeats. However, during the C3 discharge cycle, the charge rate of C1 decreases with each repetition of the oscillator (because the control voltage is lower), and the output frequency decreases accordingly. During the C3 charge cycle, the opposite happens.
The output pulse is buffered by a second op amp which then applies current to the drive transistor. The output waveform has a low duty cycle but produces a very loud tone.
This simple LM358 based electronic siren kit is now available. Download the PDF version with the parts list
- Analysis of the working principle of the sound and light controlled delay switch circuit
- Design of an autonomous plant watering system using ATtiny85
- Controlling LEDs with Node-RED in Raspberry Pi
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- How to Make a Simple Chicken Incubator
- DIY an electromagnetic levitation device
- An automated model railroad layout project using a microcontroller
- Design and production of wireless multi-location control switch circuit
- Electric vehicle battery charging protection circuit
- Delay switch made with LM431
- Call for help alarm circuit
- Language reversing alarm circuit a (1)
- Power outage call alarm circuit
- Power outage alarm circuit
- Transformer overtemperature alarm circuit
- Water boiling alarm circuit
- Boiler water level alarm circuit 2
- Water shortage alarm circuit 2
- Current transformer secondary open circuit alarm circuit
- One of the power outage alarm circuits
